Scott_Revels
"Supplier Travel" not a drop down reason for Travel when booking.
samasuraj
Hi  @Scott_Revels
Topic: "Supplier Travel" not a drop down reason for Travel when booking.
If “Supplier Travel” is missing from the SAP Concur Travel dropdown when booking, check the below.
Check:
  1.  Dropdown Configuration: Verify that “Supplier Travel” exists and is active in the configured list.
  2.  Permissions: Confirm the value is available to your traveler group.
  3.  Traveler Group: Confirm the option is available to the employee without restrictions
  4.  Profile Synchronization: Verify that the employee's travel profile and assigned configuration are current.
  5.  Dependencies: Verify whether the dropdown values depend on another field or trip type.
  6.  New Travel Experience: Determine whether the option appears in the legacy interface but not the new booking interface.
  7.  Test: Sign out, sign back in, and check whether the option appears.
  8.  Escalate: If correctly configured but still missing, contact SAP Concur Support.
Administrator Navigation: The exact Configuration Path depends on whether Reason for Travel is a:
1.  Custom Field
2.  Configured List or
3.  Part of a Booking Workflow.
“Supplier Travel” is not a standard Concur value.
It may be a Company-Specific value that requires Configuration or Activation.
Thanks & Regards
Samantha Prathikantam
@Scott_Revels I take it your company is requiring the Reason for Travel.
What is available in the drop down?
