Now when booking flights I have to remember to change the time filter because now it defaults to flight times between 5am - 2pm. Is anyone else seeing this. I entered a ticket in Concur but they are stating it was "born" this way. Which my interpretation is; they made the change and that is the way it is.
Hello @Jsajdak ,
It’s not a bug. It’s how Concur now configures flight searches by default.
This has been the case since April 2026 (important change):
In other words, the system automatically preselects a time window based on the corporate configuration.
I’m sharing a link where this is explained:
New Concur Travel, Apply Time Preference Configurations to Flight Search | SAP Help Portal
Hope this helps! Let me know if you have any questions 🙂
Best Regards,
CJ
Best Regards,
CJ
@Jsajdak "born this way" was probably not the ideal choice of words that should have been used. There was a change made to Concur Travel as @cjmarimo mentioned, so this was not the way it always was. 🙂
Hello @Jsajdak ,
Best Regards,
CJ
Best Regards,
CJ
