rhendrixok
How do I check how much it would cost to change a flight, without cancelling current flight?
@rhendrixok you will either need to reach out to your company's travel agency or contact the airline directly. The other option is to just do a search in SAP Concur Travel for the trip you want and see what the fare is, then subtract the current airfare from the new airfare.
rhendrixok
Thank you Kevin.  I did check fare differences, then joined a chat with Concur Helpdesk.  She told me I need to talk to one of our Concur Agents to make the change.  I did and all is good. Yes, just the difference in the posted fares.
@rhendrixok great to hear. 🙂
