LeighAnn1067
Canadian Concur Travelers
Client with a global program wants to create one US configurations and roll up their Canadian travelers to this country.  What if any are the challenges for expense reporting, tax implications, etc. of not having a separate country configuration for Canada for travel?
@LeighAnn1067 when you say one US configuration are you talking about a US Concur Travel Configuration or are you talking about a US Concur Expense Configuration?
LeighAnn1067
Hi Kevin,  both actually.  They already have an expense configuration and are rolling out travel in both US and Canada.
@LeighAnn1067 if they already have an expense configuration, is it for a country other than the U.S. and Canada?
LeighAnn1067
US expense configuration
@LeighAnn1067 a couple of potential issues that could arise are:
1. User profiles on the Expense side do require a default currency be assigned. If your Canadian employees are assigned USD as the default currency, then they would need to be assigned a company card (assuming you would be assigning company cards) that are issued from a U.S. bank. However, it would be a manual process to update the currency amount for reimbursements for these employees.
2. On the Travel side, it might be that Canadian users being in a U.S. Travel group might see all travel options in USD.
3. For expense reporting, you may run across tax issues as U.S. Group configurations do not use any GST, PST, etc. so I'm not sure how Canadian employees could report on this and receive any possible reclaims.
In my opinion, I don't think it would be the best way to approach things by rolling Canadian employees into a US configuration.
Now, because you are a certified SAP Concur Partner, you can submit this question to our Partner Support Portal and see if you get a similar response to mine or maybe they know a way that isn't too complicated.
rachelbrusch
Hi there,
The main consideration is currency, for tickets to be issued in Canadian currency, a separate travel country configuration for Canada would be needed. If Canadian employees are added to a US travel configuration their tickets will be issued in USD.
Rachel Brusch
