I'm not finding any Hilton hotels on this list. There are a lot of hotels under Hilton. Very surprised to see it's not included. Can I somehow get my reservations to connect to my Hilton Honors account?
@NancyLarsonRobe I'm not sure what you are asking exactly. Sounds like you want to enter your Hilton Honors number on your Concur Travel profile so it gets added to reservations you make using Concur Travel, is that correct?
Can you provide a screenshot of what you are looking at, please?
Hi Kevin -
We appear to be facing the same issue as @NancyLarsonRobe.
We just added TripLink/TripIt to our Concur platform and are not seeing a way to join our Hilton Honors Rewards number to TripLink. There is Marriott, IHG and Hyatt, but no Hilton.
Ellen
@ellenk and @NancyLarsonRobe Hilton isn't a TripLink supplier so it isn't available to be connected to for TripLink. You can add your Hilton Honors number to your profile to earn points, but as for TripLink...Hilton isn't available for connection.
How would Hilton become a TripLink supplier? should customers petition to Hilton or Concur?
