45300201
Need SAE header template for invoice
I am looking for the SAE header template for Invoice. I found the Technical Deployment Toolkit (Current) from the Expense forum, but I'm not sure whether it can also be used for Invoice, as I cannot find a separate Invoice template in the SAP Concur community.
Could anyone help me locate the SAE header template for Invoice (not Expense)?
Thank you.
Hi @45300201 ,
You can download the Invoice Technical Deployment Toolkit (ZIP file) using the link below. It contains all the import and extract templates, along with the specification guide.
If you are unable to see below screenshot, then open below link, check under  Flat File Integrations column >> Concur Invoice section.
Technical Document Portal
