MGH
Automatic Payments through S4HANA
Hi, Is anyone here using S4HANA as an ERP system and using automatic payments to the vendor instead of creating manual payments in SAP?
Hi @MGH ,
I have not specifically worked on S/4HANA integration with Concur Invoice, but below is the AI-suggested response from the Concur support portal. It appears there are certain issues or challenges involved in the process; however, the information also outlines possible resolutions and recommendations to address them.
You can refer to the detail setup steps in below given SAP Note:
Integration Setup: Transitioning from on-premise systems to S/4HANA Cloud requires specific steps. Refer to SAP Note 2924469 for detailed guidance.
MGH
Hi @PoojaKumatkar This is more like a payment status reflected in Concur for the particular invoice. I was more asking about the payments from S4HANA if anybody using S4HANA as an ERP system and payments are automatically done to the vendor instead of manual intervention.
