acdepalma
Reports for all spending by employee
I'd like to create a report that can give me all spending by a specific employee.
7 REPLIES 7
DivineKathleen
Hello @acdepalma,
Thank you for reaching out to us I will be sending you an email to get some details to assist you further.
SFuentes
Hi! I would like instructions on how to do this as well. I need to create a report that shows spending, in different categories, for each employee.
MelanieT
@SFuentes Hello! I am not sure if this is the exact report you are looking for, but you can try this:
To get the detailed wise spend of an Employee :
  • Login to Concur Travel and Expense
  • Click Reporting > Analysis/Intelligence
  • Click Public Folders
  • Click Intelligence/Analysis - Standard Reports
  • Click Expense Processing
  • Click Expense Entry Analysis Details (grouped by Employee)
This report provides detailed spending information grouped by employee and then by expense type
Melanie Taufen
SFuentes
Thank you @MelanieT . I did try this but the outcome is blank...I can't get any information. 😞
Hi @SFuentes sometimes you can open Cognos but you don't have the necessary permissions assigned. For example if you want to extract data from employees that belong to Italy but you just have permission for Portugal you won't see that information.  If you are the site administrator you can check if you have the right permissions following the steps below:
1- HOME--> under ADMINISTRATION-->COMPANY ADMIN-->and under User Administration go to USER PERMISSIONS.
2-in the Reporting Tab you can type your login id/name/email or other options to check if you have the right permission. Normally the site Administrators has Cognos Professional Author.
In the https://www.concurtraining.com/ you have resources that can help you with this topic, under Learn About Reporting
Resources and training on SAP Concur reporting solutions.
kimlight
Hi Melanie,
I have followed the steps above but no data pulls up. Does this mean nothing was submitted by the employee?
Hi @kimlight ,
Please check what i replied to @SFuentes and see if this helps.
I hope this helps.
