shanyce
Reporting: Auto Approved (by Concur System) Expense Reports Due to Sample Review
Hello!
My organization uses a Random Audit Rule of 10%, therefore some of our expense reports are bypassing the Processor and are auto approved by Concur.  How can I run a report/query in Intelligence to show these expense reports?  I'm not sure what data to select.
Shanyce
2 Solutions
MelanieT
@shanyce Hello!  I was able to take a look at your workflow set up, and reports with no exceptions are what skips the Processor step.  You can actually create a Query in the Process Reports like this:
Melanie Taufen
@shanyce in Cognos, you can use the data items highlighted in my screenshot below. From what @MelanieT mentioned, reports with no exceptions are the ones bypassing the processor approval. So, by adding Report Has Exceptions and then creating a filter on this data item to Show Only "N", you should only see those reports that didn't have any exceptions.
Don't worry that my screenshot looks different than yours. The data warehouse is exactly the same.
MelanieT
Melanie Taufen
shanyce
This worked perfectly! Thank you so much for your advice/suggestions.
