ACNoonan
Field-Level Scope Permissions for 3rd Party Application
Hello All,
I would like to allow READ permissions for a third-party application, but only for specific fields within the Expense table. The documentation on v4 API Scopes(linked below) does not explicitly mention this as a capability, but could this be possible following the listed Scope format?
If this is not possible in v4 APIs, is this possible in any of the deprecated Expense APIs?
- https://developer.concur.com/api-reference/authentication/scopes.html
- https://github.com/concur/developer.concur.com/blob/preview/src/api-reference/authentication/scopes....
Use Case: Open API access to 3rd party, but only for fields that do not contain PII.
Thank you!
@ACNoonan I recommend joining the Admin Group here on Community and posting your question there. Your question is quite technical in nature and this forum is more read by end users and not those who would have any experience with what you are asking. Just letting you know where you are more likely to get a response. 🙂
ACNoonan
Hey Kevin,
Any chance you could repost my question there? I attempted to join the Admin Group but was immediately denied.
