TJanko
Concur not opening in Edge browser
Hi everyone,
I have an SAP Concur user who is unable to log-in to Concur via the Edge Browser, but it works fine in Chrome. Are there any know issues with the Edge browser?
Tom J
rohanpatil
Hi @TJanko
Normally Concur supports all current browsers. I suggest checking users browser version against below document. Else raise a case with Concur support.
https://www.concurtraining.com/customers/tech_pubs/Docs/Z_SuppConfig/Supported_Configurations_for_Co...
rohanpatil
Hi @TJanko
TJanko
@rohanpatil ... Thanks for the help and resources! TJanko
MelanieT
@TJanko Hi Tom!  In addition to Rohan's comment, you can try to clear cache and cookies on the Edge browser. You can also try incognito (private) mode: For Chrome and Edge, press Ctrl + Shift + N to open a private window. For Firefox, press Ctrl + Shift + P.  Also, make sure you do have the latest version installed for Edge.
Let me know if either of those suggestions work or not 🙂
Melanie Taufen
TJanko
@MelanieT ... Great tips ... Many thanks! TJanko
MelanieT
@TJanko Happy to help!  Have a super day 🙂
Melanie Taufen
