I'm a bit blown away that this is so difficult to figure out but how does one get Concur to remember settings entered for expenses?
Example, my company routinely spends money with Shopify. On average, I get 10 - 12 expenses related to Shopify per month.
I have to manually enter the "Expense Type", "Business Purpose" and "Department" every single time.
I can't understand how to setup a way for Concur to recognize if an expense comes in from a recurring source, pull the info from the previous one and auto fill it.
That seems pretty fundamental to me for an expense software but to be fair, I've only recently had to take over managing a "shared" business credit card.
I've seen mention of "copying reports" but the reports aren't exactly the same each time. Some vendors bill us every two months, some are yearly, some are monthly but don't have the same cost.
Is there no template system or anything similar that will remember settings for specific expenses?
@shalas Hello! I can understand your frustration. If you are an Expense Company Card Administrator, you can map these types of CC transactions to populate with an expense type. Here are steps on how to do this.
To map Expense Types to Merchant Category Codes (MCC):
To map an expense type to a Merchant Code:
To Delete or Unmap a merchant code:
Unfortunately I'm not an admin and I don't think the admin we have will want to spend the time on it. I'll ask though. Thank you!
This is very helpful to me! @MelanieT , may I add a question to this.
We are operating multiple policies and having numerous credit cards connected to our system. Is there a way to differentiate the default expense type for a merchant code per policy/CC?
Situation is as follows: we are using a standard expense type for "Hotel". However, for one country we need to use a copy of this expense type which we called "Hotels". For most country, merchant code 220 goes to that expense type "Hotel". For the one country "Hotel" is even disabled, instead we are using "Hotels". How can I achieve that 220 goes to "Hotels" in that country and remains not "undefined"?
@shalas are these 10-12 expenses the same type of expense each time? Meaning, are all the transactions the same expense type? Usually the first expense from a vendor comes in with an Undefined expense type. When you pick the expense type for this transaction, the system usually "remembers" this expense type the next time you have a transaction from that vendor. Did that not happen?
As for the business purpose that cannot be mapped to an expense type.
For Department, is it the same department each time? The system can copy down your assigned department into expense entries. However, if the department can vary for these transactions from Shopify, there isn't a way to map the vendor to a department.
Lastly, have you tried using the mass edit option to populate the Department and business purpose fields? You can select all the entries that will use the same department and business purpose then click Edit. This will bring up a window showing all the fields that can be mass edited. You should see both Department and Business Purpose available. Maybe give that a try. 🙂
Bummer about business purpose but yes, same department each time for shopify expenses (pretty much all expenses are the same dept.).
How do you "copy down"?
I'll try the mass edit for them going forward, that will definitely help.
Kevin,
On our expense reports, the 'business purpose' is always just Business Travel. Why can't we default that in from the report header and not have to click every transaction and add that manually???
