ARJ
expenses not booked in project
Hi. a collegue booked is expense in a project but cost wasn't booked on it.
expense CTR021352592
can you pls help.
thanks
@ARJ Hello there. I'm not quite following exactly what the issue is. Also, are you working on the expense report on behalf of your colleague?
ARJ
Hi. @KevinD . a collegue booked an expense in CONCUR to be costed to a project (visible in RP0004 - Ledger Details (v3.1)) but the cost of the expense is not booked in the project.
@ARJ if I'm understanding correctly, the colleague wants to charge the expense against a certain project, is that correct? If so, is the issue that they aren't finding the project anywhere on their expense report?
ARJ
Hi
resource charged the expense against a project
in RP0004 - Ledger Details (v3.1) the expense is with project reference
but the project didn't occur in the expense
@ARJ okay, but what are you asking, exactly? We don't have any control over your company's projects or ledgers, so I'm not quite sure what kind of help you are looking for. You'd be better off asking your direct manager about this situation.
