yacoulibaly
eReceipt API with customData at entry level?
Hello Expert,
Is it possible to create receipt using Concur Receivpt API (https://developer.concur.com/api-reference/receipts/get-started.html) with some custom data eg. custom20, custom30 at entry level?
I know one way will be to create receipt first, and then make an update using Expense Entrie v3 (https://developer.concur.com/api-reference/expense/expense-report/expense-entry.html) but i was wondering if there is a way to create directly the receipt with these custome field data...to avoid any subsequence call. I will appreciate any hints
@yacoulibaly my API contact said that the Receipt APIs are not used to add data to expense reports. So, based on this statement, I would say you won't be able to add data from custom fields.
