doctorjsix
duplicate expenses
Since Friday, I've been receiving 2 emails from concur stating that Concur has received company card transactions.  When I look at the transactions, every one is listed twice.  While I only loaded 1 of each into a expense report, the remaining ones are still there as expenses I need to deal with.  How do I stop getting 2 emails?  How do I stop each expense from being duplicated?  What do I do with the duplicates still in concur?
samasuraj
Hi  @doctorjsix
Topic: duplicate expenses
Corporate Card transactions cannot be deleted by employees.
If every Corporate Card transaction appears twice and you receive two Notification Emails,
the issue may be related to:
  1. Duplicate Corporate Card-Feed imports,
  2. Overlapping Corporate Card feeds
  3. Duplicate Notification settings
  4. Incorrect Account Assignments
Actions:
  1. Verify: Compare transaction Dates, Merchants amounts and Corporate Card's last four digits.
  2. Stop Duplicates: Ask your Concur Administrator to investigate the Corporate Card feed.
  3. Existing Duplicates: Do not submit them. Request administrator assistance to resolve them.
  4. Duplicate Emails: Check Profile → Profile Settings → Email Notifications and ask the Administrator to investigate duplicate alerts.
  5. Escalate: Raise an SAP Concur Support case if the issue continues.
First, Correct the Corporate Card-feed issue and then ask the Administrator to delete the Duplicate transactions and Notifications.
Thanks & Regards
Samantha Prathikantam
@doctorjsix forgive the likely silly question, but since I cannot see your card statement, I have to ask if you are seeing these duplicates on your card statement as well? If not, then you will need to have the team at your company that assigns company cards go in and hide these transactions.
If you do see these on your card statement, then you have two options: 1. If you feel these are indeed duplicates and you shouldn't have been charged, then you need to dispute them with the card issuer. Call the number on the back of the card. If the card issuer determines they are duplicates, then they should issue a refund. It might take a while. When the refund is issued, you should see these credits flow into your Available Expenses. Once they do, add them and the duplicates to the same report. They will zero each other out.
2. If you look at your statement and determine these are legitimate conversion fees, then add them to a report and submit them.
doctorjsix
I never see a credit card statement.  That's handled by corporate.  I'll need to alert our concur and credit card people about this.
