For Meals with Attendees Expense Type:
We've set our Attendee Type Code to "SYSEMP", which allows a search of all of our Concur company employee/users.
The person can search by many options, and four of the six result fields will be pre-filled as it brings back the information for your attendee.
What's missing is the Title, which is important to us, as policy dictates the highest level should be paying for the meal.
I've gone back through documentation on the forms, but they all point to the Title in a Search option, as opposed to the option to include Title to be pre-filled. I'm not sure if the SYSEMP is linked in the back end to our Employee Import File (350 record), but we do include the Job Title which pulls into our system and reporting.
Is there a way to pull this into the Attendee SYSEMP data so our users do not have to repeatedly type in the Title? Many times they are not exactly sure of the title. It seems because there is a search option by Title there should be away to allow it.
Hi @cmakai
If the Attendee type code is 'SYSEMP', it’s likely that the attendee was automatically created based on a user generated in Concur.
Does the Employee form for your company's users have information in the Attendee title field?
I would need to look into the exact reason in more detail, but I'm offering a potential solution that might help.
If you create a custom field called 'Attendee title' in both the Employee form and the Attendee form, and have the Attendee form’s Attendee title field pull the source value from the Employee form's Attendee title field, it should display automatically. However, you’ll need to populate the Attendee title field in the
Employee form, either manually, via Excel import, or through an interface.
I hope this helps. Thank you.
This will work if title is only defined for SYSEMP. What would happen for Title on other attendee types (Like clients) ?
@cmakai have you considered using the Attendee Import file. I think this would allow you to add the title to all employees. I think you need to create the file, then work with SAP Concur to have them import the file into your site. The attendee import template can be found in the deployment toolkit where the employee import template files are found.
Thanks! Just wondering if that would "supplement" the already provided detail? I'm just wondering on the management of this process since with over 65K users in our system changing daily, if someone's termed I guess it just wouldn't link to the detail?
I was hoping since the SYSEMP must be drawing from the employee import file, that the other data could be picked up too.
@cmakai from how I understood it, the Attendee Import is a separate job. I'm not sure what happens if you add all employees to the attendee import. Maybe any duplicate information from the Employee Import is ignored and only new information from the Attendee Import is added to the employee's record in Attendee Admin. I've not tried it, so I cannot say for sure.
Will be able to answer this question soon!
Thanks. I'm going to put in a ticket to ask some questions (after reading through this documentation). I will let you all know what I find!
Updating this post
What I've learned ~ The SYSEMP is connected to the Employee import (300/305 record). Once you choose SYSEMP you can pull in your associate names, etc.
However, to pull in the Title, you must have a custom field configured in your (300/305) import, which would include the Title. Once you've configured this (which we will be doing), you can utilize the "Copy down" in the form (see instruction below) and be able to connect to that custom field. Concur Support can help you if do not have Advanced Configuration access or more help is needed.
Creating a custom field for the information is an advanced configuration that needs to be made in several steps. Below are the steps you need to create this field on the Employee level:
1. Go to Administration > Expense
2. Search and select Forms and Fields
3. Click Fields Tab
4. Select Form Type: Employee
5. Select the Custom Field from Field Name column (in the example below it shows it's defaulted to a Custom field we are not currently using on our import)
6. Select Modify Field and edit the information necessary
7. Select the type of field you want to add: Text | Amount | Boolean | Date | Integer | List | Connected List | Numeric
8. Select the access right for each role to determine if the field will be hidden, read-only or modifiable
9. Click Save
10. Select the Form Fields Tab
11. Select the Form you would like to add this new field from Form Field Name column
12. Select Add Fields
13. Choose Field created from Field Name column
14. Select Add Field
Title - Custom4
Once this change is made, the field will be available to selected for copy down on the field configuration for the field Attendee Title on the Attendee level.
✨ Once again, in our case, we will need some time to be able to have that configured (since currently Title is only on our 350 record, which populates your User Admin Travel Settings. The optional workaround is to do an Attendee import.
Concur support has provided me a Header for the Import. So far I've learned that the External ID (unique identifier) would be our Employee ID # and the Attendee Type Code (in our case) would be EMPSYS.
Once pulling in the (created) Attendee Import to populate title, we would need to configure the form/field a bit differently as the source would be the Employee Attendee (in our case).
As our company has grown and our policies have been shaped by our progress, we continue to identify things that have more importance now than they did 10 yrs ago. Our policy states that the Senior most person should be paying for meals (if a lower person pays and the senior person approves there is possibility of non-compliant behavior). By having the fields auto-populate we are saving our users time and ensuring accuracy in the data we are reporting.
As a growing company it's important to continually be looking to see what can be done to improve both ease and efficiency for the users, as well as strength and usefulness of the capability of the system and the data it can provide.
Be careful, since fields are defined globally and this could affect the "Titel" of other attendee types.
