aakashgupta
V4.0 Swagger does not list any operation
I came to know that v4.0 has introduced 3 new operations- Invoice Pay, Purchase Requests, Quick Expenses. To get the metadata of them, I tried accessing the Swagger URLs- https://us.api.concursolutions.com/api/v4.0/api-docs and https://www.concursolutions.com/api/v4.0/api-docs .  But all I get is a swagger with no operation/apis. What can be the reason for it?
"apiVersion": "4.0",
"swaggerVersion": "2.0",
"basePath": "https://www.concursolutions.com/api/v4.0",
"resourcePath": null,
"apis": [],
"models": {}
himanshugrover
Hi Team Concur,
Any update on this would be appreciated.
Thanks and Regards,
Himanshu Grover
AshleyB
SAP Concur, Former Employee
Hi All,
I have done some digging and reached the limit of the support we can provide on the community on this topic. I would suggest reaching out to your company's admin or SAP Concur rep for additional resources or support. The Developer Center would be your best resource for self serve knowledge on this topic.
If you do find your answer from another resource please share it with us here! We would love to learn what worked for you all.
Thanks for your patience!
Ashley Bragg
AshleyB
HI @aakashgupta and @himanshugrover
This is a good question. I will have to ask around to see what I can dig up for you all. This is a bit technical so it might take a little. I appreciate your patience as I work to find you all some answers.
Ashley Bragg
AshleyB
Hi All,
Following up on this:
Though I don't have a specific answer to this question yet a good resource could be our Developer Center. Here you can browse FAQs, read through how-tos, and learn more about Developer resources. Here is the link to the support page on the site: https://developer.concur.com/tools-support/support.html
I hope this helps!
Ashley Bragg
