Peacenlove613
Uploading multiple receipts as separate expenses.
Hey on the mobile app when I upload multiple images it’s only processing the first one. It still gives me the option before I upload to creat separate expenses for each image but it’s only uploading 1. Anyone else experiencing this? Any fix?
cjmarimo
Hello @Peacenlove613
Perhaps this link will be useful to you: How to do one-time multiple receipts upload and tr... - SAP Concur Community
BR,
cj
  Best Regards,
  CJ
Peacenlove613
Not the case by me. I have the option to upload images. It allows me to select up to 10 images and then asks if I want them combined into 1 expense or creat separate expenses for each image.
The issue I’m having is it’s only uploading 1 of the 10 images selected.
@Peacenlove613 could you please provide the exact steps you are following to try and upload multiple receipts, please? It helps to know exactly what you are doing. 🙂 Paint a picture, if you will.
