Has any one been able to export a list of Clients and or Department from list management in excel, when I follow the below instructions I'm not getting the complete information.
@Daniel1968 which of the two are you trying to get the list for, Clients, Departments or both?
I take it that the by "not getting complete information" you can see that some of the clients and/or departments aren't showing? Are there many not showing or just a few? About how long of a list should these be and how many do you see being returned?
@KevinD : I am trying to extract Connected list information from Cognos. Please let me know is it possible to do so as I could not see much fields under [Expense].[Custom and Connected Lists].
Warm Regards
Venkat
@Venkat I would start with data items List and List Item. It will be tricky though because it will put all the list items in one data column, so you will need to get creative to separate out the different levels of the list so each level displays in its own column. You might need to do a Repeater Table or a Master Detail type report to achieve this.
@Venkat for this specifically...no. In all honesty, the Cognos reporting tool is designed more for analytics so companies can better track spend rather than pull list items and see how things are configured. Without creating a repeater table or Master Detail report, the returned data is going to show all list items, regardless of what level, in one column. This makes it a bit tricky to create this report and have each level of the list in its own column. You likely will need to create a few different queries in your report, one for each level of the list.
