yichengji
SAP Concur upload pdf receipt system will change to image format
Hi when i using Concur expernses upload pdf receipte/invoices and submit, the system will change my pdf format recepte/invoice to picture format, anyone can solve this?
Path:
SAP Concur - create new report - manage expenses - upload pdf format receipt/invoces - submit
when submit succesfully, and i go to the report click "manage invocies" - open in new window, the pdf invoice will change to picture format.
8 REPLIES 8
Hi @yichengji ,
I tried the same in our sandbox but for me it is working properly. I uploaded .pdf receipt, submitted expense report and opened receipt in new window from manage receipts sections.
When opening receipt in new window it doesn't shows any file name, instead it is showing some system generated long unique id. But when I downloaded that receipt using download option then receipt format is still. pdf.
Can you please try to download receipt and check in which format it is getting downloaded.
yichengji
Path: Manage Receipts - View Receipts in new Window
it shows below
normal China Invoice PDF looks
System convert PDF invoice to image file.
Company: Syngenta
Environment: Test environment
Report key:
1444648
Hi @yichengji ,
This is how receipt/invoice will look like when multiple receipts or multiple pages invoice is uploaded in Concur. Basically, system keep on appending every next receipt to the previously uploaded receipt.
 Irrespective of receipt format whether its .jpg, .jpeg, or .pdf, all receipts will be displayed in same way when you try to open in new browser window.  Also, system will consolidate all expense entry line item receipts, append it together as one document and it will be displayed as 1 single pdf document when you open it in new window from manage receipts section. Therefore, by default invoices will get downloaded in PDF format only.
This is systems default behavior and there is no issue in Concur.
yichengji
Sorry i did not describe things clear. Let me descrive the things again.
When i upload serveral PDF format receipts, at this time these original pdf receipts contents can be copy.
And when i finish uploading and submit, several pdf recipts merge to one pdf, but when i open this merged pdf, the content of this pdf can not be copied, which means, system convert my pdf format to picture, and then merge to one pdf.
But this is not always happen, system sometimes happen, sometimes not.
Hi @yichengji ,
I got your point, and I tried the same in our sandbox. I was able to copy paste text from PDF before and after submitting invoice/receipt.
Possible that receipt text which you are trying to copy is a scanned receipt and not the original pdf copy. If it is a scanned document, then in that case system will not be able to copy text.  This is the only reason I could think of.
You can try uploading 2 original pdf documents/receipts/invoices and then check whether you are able to copy text from PDF after submitting an expense report.
Note - Please ensure those receipts are not scanned receipts and saved as pdf format.
Also, I am just wondering why anybody would copy data from attached receipt. what is the use of that? Receipts are only for the reviewing purposes and to validate whether user is claiming correct expense amount as per original receipt.
yichengji
Hi
The orginal pdf document is not a scanned document. as i  said, not everytime pdf format will convert to picture format when i done with uploading. so i would like to know why system will convert orgianl pdf file to picture when uploading.
regarding your question, China goverment requeire all the invoices should be orginal files to be stored in the  system. The origianl invoices is pdf format with content can be copied. So that's why we do not want to see the pdf inovice convert to picture when uploaded.
I would like to know the deep reason make the convert change?
Hi @yichengji ,
Thanks for clarifying my question. I have never come across this issue before, hence, I may not be the right person to answer on this.
Initially I thought because of scanned documents it might have happened, but you clarified my doubt.
I would suggest raising support ticket with Concur. They will investigate it further and provide you the reason.
JorgeL
I understand the problem. This however is not a Concur issue. I have come across this issue via email or when opening files with a browser.
Although while it may look like a picture file because you cannot copy the content, Concur keeps the original format of the file uploaded. This has to do more with the file or with which platform the file is opened. I cannot offer a solution, this is just a general file issue.
