JPitisi
Rounding Up
This question has come up before, but I wanted to see if anything has changed. Mileage calculation is rounding up/down, is there a way to change it so it doesn't round up/down?
Thank you.
@JPitisi the mileage has rounded up/down for as long as I can remember and I've been at SAP Concur 16 years. There isn't a way to change this. It is hard coded into the system.
