robd1974
Reporting question
I am trying to find a report that shows the status of report submissions and if the manager has not approved.  I am an admin and cannot locate where to find this report type, it is not in my Analytics tab and I cannot find out where else it may reside.
@robd1974 Analytics does not have this report. However, I see you are an expense processor. Go to Process Reports. On the process screen, use the drop down fields to select Approval Status Equals Submitted & Pending Approval. This will give you a list of all submitted reports not approved. At the bottom of the results, you should see an Export to Excel option. There you go. 🙂
Aldridge73
Hi have you looked at the reports in this folder - Expense Processing, there are a few reports called workflow?
Littlelegs likes to travel!
robd1974
i don't see an option for Expense Processing.  Here are my options:
robd1974
this worked!  I tried looking at this before and thought it was going to pull only the reports I can approve and not the firm.  Thank you!
@robd1974 glad it was what you needed. Now go get on those approvers and tell them they have work to do. LOL.
