Tkat
Receipt
How do i detach a receipt if it was allocated to the wrong expense? Also, two charges are showing for one event. The first is the original charge before tip was added. And the second line is the final charge after the tip was added. The system makes it appear like there were two charges when in fact it was one charge, but the before/after tip is showing two lines. Please advise on how to fix.
samasuraj
Hi @Tkat
Topic: Receipt
SAP Concur – Incorrect Receipt Attachment & Duplicate Charges
These are two separate issues that should be corrected before submitting the expense report.
  1. Detach a receipt attached to the wrong expense / SAP Concur – Receipt & Duplicate Charges
  1. Open Expense → Expense Report → Select the Expense.
  2. Open the attached receipt or receipt image.
  3. Select Detach, Remove Receipt, or Delete Receipt Image, if available.
  4. Attach the receipt to the correct expense entry.
Remove only the incorrect receipt association, not the underlying corporate card transaction.
Available options depend on your company's Concur configuration.
  1. Two charges/Duplicate Charges for One transaction (Before and After tip)
     This may be a temporary card authorization followed by the final settled charge, rather than two actual purchases.
  1. Check the card issuer's statement to confirm whether both amounts have posted.
  2. If the original amount is only a pending authorization, allow time for it to disappear.
  3. If both appear as posted transactions, contact your Corporate Card Administrator to investigate a possible duplicate.
  4. Submit only the legitimate final charge, including the tip. Do not delete or mark a genuine corporate card transaction as Personal merely to clear the duplicate.
If the receipt cannot be detached: For automatically matched e-receipts, remove the expense entry from the report
so it returns to Available Expenses, then use Payment Type → Separate, where supported.
Correct the receipt association and verify the final settled card amount before submitting the report.
Thanks & Regards
Samantha Prathikantam
