MNash
Pcard Statement Report
When I move expenses to a report, they all get flagged that they are Pcard expenses and must be removed and attached to a Pcard Statement Report, but I can't find any documentation on that. I'm stuck!
@MNash I looked at your profile and you have not been assigned the Company Bill Statement user permission. By having this permission, the system will automatically place your PCard transactions onto the correct report type, which is a Statement Report. I'll send you a private message with the names of people at your company that can add this permission. Check the little envelope icon near your name in the upper right-hand corner.
32 REPLIES 32
keagansatterfie
That's a great aid! cookie clicker
Sincerely
BConerd
Hello Kevin,
I am having the same issue, could you assist me with this as well?
@BConerd sending you a private message.
AbbyN
Hey Kevin!
I'm new also and have the same issue. Can you please assist?
@AbbyN @rhuert4 and @CharissaRuffin my three suggestions:
1. If you have a company notes section on the home screen of SAP Concur, look to see if there is any link or contact information for getting help.
2. Speak with your direct manager to see if they can provide some insight. Unless your manager is brand new as well, they should have either experienced submitting their own expenses or approving reports.
3. Your site administrators are usually people in Finance, Accounting or Payroll/HR departments. I would reach out to them.
I cannot give one answer that would cover all three of your situations since different companies do things differently.
rhuert4
New Member - Level 3
Hi I'm having that problem also. Can you please help?
CharissaRuffin
I'm apparently having the same issue.  I'm getting the error: P-card transaction cannot be submitted on Expense Report. Please contact your Administrator.  Please share who I should contact.  Thank you.
michellencp
Hi, this affects me too. Any way to check my account?
@michellencp if you open the report in question, click on Report Details. From the drop down select Report Header. When the header details appear look for a field labeled Policy. You can change the policy of the report to match the types of transactions.
If you do not have the option to change the report policy, please let me know.
michellencp
Hi. In the Header details, there is no field labeled "Policy." I have reached out to internal folks hoping to get help with my permissions, but have not heard back yet.
Gwright
I have this same issue can you assist me with this?
@Gwright there are a few different issues regarding P-Cards in this thread. Could you clarify your issue please?
Gwright
my pcard transactions are not moving to a expense report but the app says that I have 23 available expenses
@Gwright your company is using our Company Billed Statements feature. How this works is the system will automatically create a statement report for you when your P-Card transactions upload into your Available Expenses. In your Open Reports, you should see a statement report (this is basically an expense report but only for PCard transactions) named PCard report. You should also see the date range of the statement period as well. I don't know why you don't have one for the statement period of June 26 to July 25th. Because these statement reports are based on a defined date period, you can only submit PCard expenses while the statement period is open. Unfortunately the statement period for your 23 transactions is closed. You will need to sign in to your account and look in the Company Notes. At the bottom of the Company Notes section is a phone number for you to call to see how to handle these transactions.
The other thing with the PCard transactions is, they cannot be added to a regular expense report, as you have experienced by the Alert message you received.
If you use your PCard here in the next few days, look to see in the Open Reports for the Statement Report to be created for you by the system.
After you call the number, could you come back here and let me know what they tell you for how to reconcile the PCard transactions, please?
Gwright
this is the message i get when trying to put the expenses on a reportGwright_1-1690310231433.png
adremi
Kevin,
Resurrecting an old thread but I am having this same issue now. " Pcard expenses and must be removed and attached to a Pcard Statement Report."
This is something new as I have been able to do statement reports in the past. But now I do not have any option for statement reports.  Are you able to check if I have been assigned the Company Bill Statement user permission?
@adremi It appears this permission was removed.
If you sign in to your account, click Read More for the Company Notes section on the home screen. You will see contact information for help with Concur Expense.
davidcartercox
Kevin I am having the same issue can you advise?
@davidcartercox you don't have the statement report permission. I'm sending you a private message here on the community with a few names to contact.
