mponter
Need help joining Concur Expense with Concur Travel Data
We are using the Concur API to import records from both the Concur Expense and Concur Travel modules. Is there a way to join these two based on a unique key?
aamangulati
Hi, were you able to find a solution to this?
kreddy
any solution to this type of a problem?
@kreddy My API contact is currently out of office. I'll try to get in touch with him when he's back.
kreddy
@KevinD any update on this, is your API contact back?
TChapman
There is no link from the Travel Itinerary to one or more expense reports.
As for expense to Travel, I do not see a field for getting an itinerary associated with an expense entry. Some clients do require the itinerary to be associated with an Airfare expense (for example), but I don't see a dedicated field for that link.  I do see an ereceipt field in the expense v4 but I am unsure what it returns (you can only test in production).
My recommendation would be to associate expenses based on dates as the itinerary does have an airfare start and end date (which might not be accurate with actual start/end due to delayed flights). or use hotel start/end.
