yvathumilli
Need help in creating a deep link url to directly navigate to the Expense Report via IDP
Hi All,
We are sending few alerts to Expense Report approvers when they have pending approvals.
Is there a way to generate a link which directly navigates the approval page for a specific report while still utilizing the SSO (through our IDP)  ??
I tried this https://developer.concur.com/api-guides/expense/deeplink-url.html but still it takes to the login screen and does not go through the IDP that is configured.
Thanks in Advance.
Yaswanth Datta
MichielS
Hi Yaswanth,
I'm not sure if this is going to work but in the past I had that issue when linking from excel to a different application through SSO
I used a custom function to call the link through shell (in vba) that way it would go through the SSO and open the direct link. I hope this helps.
Public Sub OpenURL(ByVal sURL As String)
'https://docs.microsoft.com/en-us/windows/win32/shell/shell-shellexecute
Dim oShell As Object
Set oShell = CreateObject("Shell.Application")
oShell.ShellExecute sURL, "", "", "open", 1
If Not oShell Is Nothing Then Set oShell = Nothing
End Sub
kjudy
I don't suppose you ever solved this issue, I ran into the same issue. I can use an Okta embed link that will log them in and drop them on the homepage, however when I attempt to use the deep-link specified in that doc it drops them on a generic login page, unless they're already logged in via Okta. I haven't found a way to combine the two either.
