brianruhmann
Missing required field: Location Name, Department.
Some of my expenses have this alert.  The boxes are greyed out and will not let me add the location or department.
@brianruhmann try creating a new report. You should see the Location field is active when you first create the report. Then you should be able to add a Department.
Then go to the report that has the Alert about this, select all the items on the report, then use the Move button to move to the new report. See if this clears up the issue.
brianruhmann
That worked. Thank you for the help.
