deyang
Missing receipt affidavit - where is it in updated website?
Hi. The Concur platform changed and I can't see where I can choose the missing receipt affidavit option.
Thanks.
Meena_K
Yes, you are correct. The delegate will not be able to view the Missing Receipt Affidavit option. This option is available only to the staff member, who must complete and attach the missing receipt declaration themselves.
lmlang
Hello
If you are creating an Expense report, you should find it :  Manage Receipts > drop down and choose >Missing Receipt Declaration
If you are an Admin, the path is: Expense Admin >Policies>
Within the policy there is a section where you can check 'Missing Receipt Declaration' to enable for that policy and a comment section to add your company’s verbiage  ‘ Declaration Statement/Acceptance’
This is the path on our newer UI. Hope it helps.
deyang
Thanks for replying. Unfortunately, the only options that I see in the drop-down menu for Manage Receipts, are below. It used to be there before the platform changed recently.
@deyang what @lmlang said is correct. The Missing Receipt Declaration is still found using the Manage Receipts link on the Expense Report. That didn't change with the recent UI update.
deyang
That's weird then, because I don't see it as an option. I am a delegate for staff, but now I think I remember something... delegates can't see the option for missing receipt affidavit. The staff member has to do it themselves.
Meena_K
deyang
Yup thanks to all. I guess I had to think back to what a colleague had already told me some months back. 🙂 Thanks to all who had answered!
