kgrate
Intelligence Reporting
Is there any document or guide that provides descriptions of the standard reports available in Intelligence?
Hi @kgrate ,
You can refer to the below standard report catalog where you can find description for each report.
https://help.sap.com/docs/SAP_CONCUR/d314a525472c49548219b560516c9b8d/1c3f6182700b1014a46a108435d328...
Hi @kgrate ,
kgrate
Thank you!
