AWal75
Images not loading when sent via [email protected]
When I forward emails to [email protected] the recipets show up in my library without any images.  Particulaly anoying as I typically take a picture of recipets with my camera and send the email to reconciliation later to the actual expense.  This is a gloabl issue with any Jpeg files only.
31 REPLIES 31
@AWal75 I can understand your frustration. May I offer two alternatives?
1. Take a picture of your receipt with your mobile phone and then email it to yourself. Once you receive the email, save the image on your computer then you can upload the image to your expense from your computer.
2. Use the SAP Concur Mobile app. This allows you to use the app to take a picture of your receipt which uploads the receipt to your available receipt in less than 1 minute. It alleviates having to attach the receipt to an email and send to [email protected] and it takes several minutes less to have the receipt available.
dsbays
I am having this same issue on emailed receipts sent to [email protected]. It's particularly frustrating for airline receipts I try to forward. I've used other expense reporting services before like Expensify and never had this issue. The solution above doesn't work.
ChadM
SAP Concur, Former Employee
Hello @AWal75 and @dsbays
Sorry to see you are having issues around this. I'd like to send you over to our support teams to see if they can look closer. Can you Private Message me on here? I'd like to collect more information to see how we can help.
Chad Minnick
kallen51465
I recently opened a case about this issue.  Case # 16430105.  Our users had previously been able to forward emails from hotels to the receipts@concur email address with pdfs of folios attached, and the images that would upload would be of the folio.  Within the last 3 weeks our users are forwarding these emails and now the body of the email appears with a red x for the attachment.  Something has definitely changed and no adequate response has been provided yet.
Any ideas?
@dsbays are the airline receipts you are forwarding attached to an email sent by the airline or is the receipt embedded in the body of the email?
I'm asking because if it is embedded in the body of an email, then it most likely is in html or rich text format, which isn't a supported receipt format. Receipts must be in pdf, jpg, jpeg, png or tif, tiff format.
This could be the cause of your issue. Without seeing exactly what you are forwarding to [email protected], I can only speculate.
Let me know if this is what is happening or not.
davluna
I am a little confused so I want to make sure I understand. The last time I called to ask about emailing receipts I was told to have my users email them to [email protected], and not [email protected]. Which email address should I be directing my people to use?
@davluna If you have purchased our ExpenseIt option, then you should be emailing receipts to [email protected]. The [email protected] is an email address for users to email in receipts and have them stored, nothing else. Emailing receipts to [email protected] will actually create expense entries for the users they can add to expense reports by having the receipt image read by OCR technology.
Actually, users can use both email address, but the most efficent and better option is the ExpenseIt email address.
davluna
@KevinD Is there a way to check if we have purchased ExpenseIt? I came on board after Concur was implemented so I am unsure. Thanks!
@davluna the easiest way is to log into the SAP Concur mobile app. On the home screen, look for the camera icon. It should say ExpenseIt. That will let you know. Customers who haven't purchased ExpenseIt don't see this.
davluna
@KevinD Thank you! I was able to confirm we do have it. Thanks for your help!
dsbays
They are embedded images which is the norm for virtually any emailed  travel related receipts and the fact that Concur doesn't support this is a major problem. Any other expense reporting service (Quickbooks, Expensify, etc) has the ability to effortlessly forward travel or other emailed business related receipts with images, convert them to a PDF and deposit them in your receipt library. I will be recommending that my company switch providers.
Stepholdis
I am having the SAME issue and this has never been a problem until recently! I can’t pinpoint exactly when this started happening but for example I know for certain I have been able to forward Uber receipts via email to concur and now they no longer work (it returns the red x in the image as somebody posted above).
Concur - is somebody working to resolve this?
@Stepholdis hello there. I've posted your issue internally to our Receipts Slack channel. I'll keep you posted on what I hear back.
@Stepholdis has this issue resolved?
GeorgeD1
I too am extremely frustrated with the receipts functionality. Once a pdf is attached, it is not visible in the expense view. The panel just shows an "open" button which forces a download. Very frustrating as it causes one to have to toggle between the concur interface and a pdf viewer. Can this be resolved?
@GeorgeD1 Hello there. I wanted to see what you were experiencing so I looked at your expense report and it appears the PDFs are displaying properly. Are you still just seeing the "open" button? If so, could you post a screenshot here for me, please?
GeorgeD1
Thank you Kevin. This is what I see in the right panel of the expense:
@GeorgeD1 when I look at the expense, I see the full receipt, so at least we know it is there. I've posted your issue internally to see if it is a browser setting or something like that you might need to adjust. I'll let you know when I hear back about the issue.
@GeorgeD1 which browser are you using? Are you on a PC or Mac?
GeorgeD1
MacOS 11.1. Chrome 90.0.4430.212 . THx.
