simonref
ICS native Integration in Brazil
Has anyone implemented ICS in Brazil.  In SAP we have tax codes which have multiple Tax Conditions even when 0%.  When posting with ICS it fails for reason eg
“Posting failed. Check customizing for tax code V0 of country/region BR.”
It always posted fine when using SAE
@simonref did you work with someone from SAP Concur on the ICS integration? If so, that is who I would suggest you contact to see if they can provide some guidance. This forum is trafficked more by end users and not those who would work with ICS integrations.
