MEcnx
ICS - Financial Integration
How can I put the Concur User ID into the FI posting document?
2 Solutions
NTS
Hello @MEcnx
you have already user employee number in all postings.
If you want to add more info you will need to use ICS Badis, check BADI_CTE_FIN_POST_ADJ_DOC~ADJUST_POSTING_DOCUMENT.
Hope it helps.
NTS
Hi @MEcnx
You can try with the same BADI or BADI_CTE_FIN_POST_DOC_CHANGES.
Regards
NTS
Hello @MEcnx
Hope it helps.
MEcnx
Thanks @NTS !
If I need to change the position of some data from the Text field to the Reference field, should I also use a Badi?
NTS
Hi @MEcnx
Regards
