- Mute
- Subscribe
- Bookmark
ExpenseIT feature for test site
Dear Members,
Is it possible to make ExpenseIT feature activated for only test site. We want to check if system is properly reading the receipts. I want to activate in web browser only.
Also I have a 2nd question, my client won't have credit card feed in setup. So whenever receipts will be scanned it will be default to cash charges. Will users be edit date, expense type and amount for those charges after system scanns them?
- Mute
- Subscribe
- Bookmark
Hello. I can't answer your question about the test site. However, I can tell you that once a receipt has been scanned, dates and expense type can be changed. ExpenseIt can only make best guesses for the expense type, so we end up changing this field to match our company definitions.
- Mute
- Subscribe
- Bookmark
- Mute
- Subscribe
- Bookmark
I'm not sure if the amount can be changed after the scan since I haven't tried that. However, when you scan the receipt, you are asked to verify the amount before anything is saved and can make changes at that time.
- Mute
- Subscribe
- Bookmark
Hi @MSteele thanks. I have another question, suppose if I am changing date or amount or expense type before submitting , in that case will the approver be able to see that in audit trail? Means I want to know if users are changing details of expenses so that if anything wrong managers can review and reject
- Mute
- Subscribe
- Bookmark
I don't think those type of changes are listed in the Audit trail. From what I know, the Audit trail is listing changes in the report status - approved, returned, processed. The manager can always reject a report (as can the processor if the manager misses something). When a report is rejected, an explanation needs to be provided so the user knows what needs to be corrected/changed.
- Mute
- Subscribe
- Bookmark
@Saikat I'm not sure if ExpenseIt can be turned on for a test site. However, you can test with a user in a production site. Just make the user a test user. Do you have test users set up?
- Mute
- Subscribe
- Bookmark
Hi @KevinD no production is not available yet. We only have the implementation site where we are implementing the system. Just wanted to check if this feature can be enabled in test site so that we can see scanned receipts.
- Mute
- Subscribe
- Bookmark
@Saikat I'll have to post internally to see if this is something we do.
- Mute
- Subscribe
- Bookmark
@Saikat I was told that ExpenseIt can be turned on for a test site. 🙂
- Mute
- Subscribe
- Bookmark
So to turn that on what will be the process? And will I be able to use my same test user data in the mobile app ?
