Mbreaith
Duplicate Transactions on same employee
Hi!
Employees are receiving duplication errors on their own expense reports because the transaction amounts are within a certain percentage. Is it possible to have the audit rule to only flag when it's a true duplicate: vendor name, amount and transaction date. Excluding the expense type. Is that possible?
Kind Regards,
Mary
cjmarimo
Hello @Mbreaith,
Duplicate detection rules are primarily designed to compare:
  • Expense Type
  • Transaction Date
  • Amount
If any of these criteria do not match, the transaction is generally not considered a duplicate. In addition, Vendor Name is not part of the standard duplicate detection criteria.
The Duplicate Transaction Variance option is specifically based on (Duplicate Transaction Variance | SAP Help PortalšŸ˜ž
  • The same Expense Type
  • The same Transaction Date
  • The same Amount, or an amount within a configured variance percentage
  • Expenses submitted by the same employee
Audit Rule - Duplicate Transaction CheckAudit Rule - Duplicate Transaction Check
Therefore, it is not possible to replace the "Expense Type" criterion with "Vendor Name" using the standard Duplicate Transaction Check or Duplicate Transaction Variance functionality.
āœ”ļøHope this helps! Let me know if you have any questionsāœ”ļø
  Best Regards,
  CJ
cjmarimo
Hello @Mbreaith,
  • Expense Type
  • Transaction Date
  • Amount
  Best Regards,
  CJ
Mbreaith
Thank you!
How would I update it to be an exact match on the amount and not within a percentage range?
Kind Regards,
Mary
Helo @Mbreaith ,
Unfortunately, the standard Duplicate Transaction Variance audit rule is designed to work with a percentage variance and does not support an exact amount match. SAP Concur states that all variances are percentage-based and that the Equal operator should not be used with this condition.
  Best Regards,
  CJ
