Harsha
Display Balance Amount
Hello All,
Our company allows an expense that can be claimed by the employees every calendar year. We have set up an audit rule in Concur to prompt an employee when the limit is reached.
Is there a way to display the balance available to the employee? For example, if the allowance is $500 and the employee has claimed $100, can we display the available balance as $400 in Concur?
Thank you in advance.
Harsha
@Harsha I want to preface my response with, I certainly do not have all the answers when it comes to SAP Concur products. However, I have been around a while and know what I have and have not seen. I have yet to see what you are asking for. I lean towards the answer being that it isn't possible, but I would like to see if others on this Community have had any experience with something like what you are asking.
If you are wanting to provide users a way to see their current balance, I can offer a workaround. You could use Cognos reporting to Burst a report to all Approvers. The bursting ensures each approver only sees data for those they are the assigned approver. The report could show the current amount they have spent on that expense type. I believe you could create a calculation in the Cognos report to subtract the current amount spent by the yearly total to see what they have left over. The bursting also allows for sending the report via email to each approver so they can share it with their teams.
Let me know if this is something you think might work for you.
Thank you @KevinD . We are using the Cognos reporting to provide an update on the balance for this particular expense type. I was more wondering if anyone has a solution for real-time display of balance.
Harsha
@Harsha I've not come across any real-time display of the running total for an expense type.
tkgudmunson
Hi Harsha! Did you ever find a solution to this? We have a similar Expense Type we're trying to create that is only allotted a certain amount a year and it would be nice for the user to know if they've submitted for the year before trying again 🙂
Tayler
Kind Regards,
Tayler
Tayler Gudmunson (she/her)
Treasury Supervisor – Payables and Expense
Schweitzer Engineering Laboratories
@tkgudmunson If you are looking to prevent a user from submitting more than the allotted amount for the year, this can be achieved through an Audit Rule. The rule only tracks the spend for a calendar year. For example, user A submits the expense in December. When January comes around, user A can then submit the expense again, because the calendar year has started over.
There is an option in the Audit Rules that looks at the Amount-yearly total. This is what you want to use. The rule needs to state the Expense type, and the Amount-yearly total Greater than whatever that total is.
Let me know if you have any questions about setting up the Audit Rule.
