Venkat
Deployment tool kit
Please share the link to access the latest Technical Deployment Tool kit.
Warm Regards
Venkat
2 Solutions
@Venkat I don't have access to a zip file for all three of those modules. The link I sent is what we have. We don't zip them up.  You should be able to download all of the guides though and zip them once downloaded.
Kmilogon
Hello all,
I found article 000066646
Where the following link is mentioned:  https://assets.concur.com/concur_services/technical_consulting/technical_document_portal.htm
Camilo González
IT-GFS Purchasing – Principal System Analyst
Boehringer Ingelheim España, S.A.
@Venkat I'm not sure if this is exactly what you are looking for, but take a look at this link and all the guides it has: http://www.concurtraining.com/customers/tech_pubs/_Docs_CCC.htm
Venkat
Thanks @KevinD for your response. However, I am looking for a ZIP file which has all Import and Export guides. Please help me for Request, Expense & Invoice.
Venkat
Kmilogon
Hello all,
Camilo González
Venkat
Thanks for sharing the link. Is this the latest one
