Kellen
Concur expense integration through file
Hi
The Company doesn't have ICS integration, and they are using Concur Extract Services to generate a custom CSV file containing expense report data, which is converted into IDocs for import into SAP ECC 6.
They currently use IBIP card transactions, but they will implement now CBCP Transactions. But they would like to have this transactions exported from Concur in two different files. Is that possible?
Were I can find more details about this kind of extraction?
Hi @Kellen ,
Custom extract is feasible based on certain criteria. Ex. in your case, it is payment type IBIP/CBCP.
You can raise a support ticket with Concur and they will let you know whether it is billable or not billable.
Refer below similar case.
Kellen
Hi Pooja
Thank you for the information.
Regarding the Concur Standard Edition, do you know if it is possible to do that? Because in the example is was a Professional edition case.
Where can I raise this support ticket to SAP Concur to have more information?
