dxh798
Cognos report for concur Reports sent back duplicating rows on output
I have created a report with these fields but the output I get duplicate rows for reports sent back they have the same exact date/timestamp.
We do have reports that are sent back multiple times but they should not have that duplicate timestamp.
I was instructed to add the field [Expense].[Expense Report Workflow Trail].[Current Workflow Flag (Current = 1)]
which I did, and then filter with [Expense].[Expense Report Workflow Trail].[Current Workflow Flag (Current = 1)]=1
I'm not sure I have this filter correct because I'm still getting duplicate rows on the output. Is there some other way to narrow down the output or do I have this filter in there incorrectly?
thank you
Dawn
thanks
Data fields:
Expense > Expense Reports > Report Header Infromation > Employee
Expense > Expense Reports > Report Header Infromation > Employee ID
Expense > Expense Reports > Report Header Infromation > Report Name
Expense > Expense Reports > Report Header Infromation > Report ID
Expense > Expense Reports > Report Header Infromation > Report Number
Expense > Expense Reports > Expense Report Workflow Trail > Step
Expense > Expense Reports > Expense Report Workflow Trail > Role
Expense > Expense Reports > Expense Report Workflow Trail > Step Action Date/Time
Expense > Expense Reports > Expense Report Workflow Trail > Employee Assigned to Step
Expense > Expense Reports > Expense Report Workflow Trail > Status Upon Step Completion
Filter:
Status Upon Step Completion = Sent Back to Employee
grodriguezproje
Hi @dxh798
There are 4 standard reports related to workflows, did you try to use them? . You can copy them and then you can edit in case you need to change something, when building reports you should check if you need to apply (Exclude Parent Entries filter or Exclude Itemizations depending on what you want to achieve)
They are in the following path:
  1. Team content
  2. Intelligence - Standard Reports
  3. Expense Processing
dxh798
Yes i do know where the reports are and they do not have what I'm looking for. I'm also very well aware of excluding parent entries.
@dxh798 I just built a report based on the data items you posted. I didn't see exact duplicate entries. I did not use the Workflow Instance data item.
What is the name of your report? I'd like to go in and take a look at your actual report to see if I can find anything.
dxh798
Kevin,
The location of this report is here: DXH798@PSU.EDU_56122")/folder[@name='My Folders']/folder[@name='Sent Back']/report[@name='reports sent back']
 When i remove the filter for [Expense].[Expense Report Workflow Trail].[Current Workflow Flag (Current = 1)]=1 i still Get duplicate values with the same exact time stamp for the cost object approver. I should have added that I'm only getting these for cost object approvals. We have a budget admin approver and a financial officer approval step on all our emp trav policy reports and that is where it's duplicating. It's listing out the budget admin twice for any cost object approver for the same report.
thank you
