michael_brescia
Cannot print/view itemized Expense Reports
Hello all - I am having issues printing/viewing my expense report with the itemizations listed.
When I go to view the PQTG Detailed Print Report and I check the "Show Itemizations" box, the page won't show the details in the report.
Can anyone help on what the issue might be? Thank you!
19 REPLIES 19
@michael_brescia I pulled up your report and had the same issue. I'm not sure what would be causing this.
Are you required to print off a copy of this report?
michael_brescia
I submitted my report for approval, however my manager and I would like to have the itemized report printed and saved for our records. I checked Concur today and I still can't print the itemized report.
Mike
Capnflyright
I have the same issue and yes my employer requires itemizations and reports to be emailed to them before submitting as well as the original OP. I really need this to be fixed.
bryanpeng
I have the same issue on requires itemizations and reports to be printed out after submitting.
When I go to view my "Detailed  Report - Global" and I check the "Show Itemizations" box, the page won't show the details in the report.
Thank you.
Bryan
The best way, we found, to print the reports is, first "Save as PDF" then print.  This is the only way to actually print the itemizations and receipts.
DLamont
Patteb
I tried that. Doesn't work...
The report is blank except for the bar codes.
frustrated
Hello
So many useful efficiency functions have been lost with new Concur version.  Loss of Access to Receipts Library while producing report is a huge step backwards.  Now the inability to Print a report for records or review is another LOSS.    Cannot print it or save as PDF at time of submitting, or from the Libary.  This is another major pain.   Why would Concur bother replying if we are 'Required to print the report'...  why else would we users are asking about if we did not?
frustrated
I stumbled on a workaround.  Instead of clicking on the useless Print-Share , click on the Claim Details option to left of Print-Share,  then  scroll down to Allocation Details, which shows the report,  then a functioning Print report option appears.
EeMun
We would like to check if concur team did look into this issue? We would like to know on this update. Thanks.
hokoniet
I have the same issue on requires itemization and reports to be printed out after submitting.
Thanks for your feedback,
Holger
cro_user
Hi, I have same problems. When I want to print Receipt Report I can only see bar code and attached bills.
Summary and details is constantly loading in loop without any result.
sunwei
我有同样的问题。 当我尝试打印收据报告时,我只能看到条形码和附加的账单。
摘要和详细信息在循环中加载,没有任何结果,联系了所有可能的支持,结果发现故障仍然存在......
sunwei
The experience of not being able to print reports was really bad. Take a guess: how long does it take the concur team at SAP to fix this problem, or have they not received a report yet
pksink
We seem to be having this same issue.  Would be great to have a fix!
RobertGarrick
I've had an issue yesterday whereby when I click to print "front cover" I get just a bar code and nothing below and when I try to print the "detailed report" I just get the spinning wheel. Help
cro_user
I run on this problem on Friday but today I manage to bypass it. Instead of using Mozilla Firefox I opened concur site via Microsoft Edge and through that browser I can print normally.
Patteb
I've tried Chrome, Edge and Firefox. Doesn't work for me. Same blank report with "bar codes" only...
frustrated
The Print/Share option no longer works in the new version.  I have found I can print by clicking instead of Claims Details/Allocation Summary, and a functioning Print optionmagically appears at bottom of the page.
Patteb
This is how it looks for me. No printing option at bottom of the page...
