charl16
Can't attach pre-approval to expense report, red warning that I can't seem to clear.
charl16
@charl16 I see two approved Travel Requests in your profile. These should be available to assign to an expense report.
@charl16 I'm not sure why the approved Travel Requests aren't showing up. The only guess I have, and it is a complete guess, is that the hotel expenses on the report have a date outside of the Travel Request dates. The travel request is 5/29-6/3. The hotel expenses show a date of 6/4. That is the only thing I can think of. However, if you delete these, then you when you add them to a new report, it is going to ask for another Trip Pre-Approval.
I do think you can create a travel request after the fact, so you would need to create a new request with the date of 6/4 as the date of your trip. Put in the amount of the hotel. You would need to have the Trip Pre-Approval approved before it would be available. Give that a try and let me know if it works.
Oh, by the way, on your PB Travel 2 report you had a car rental item showing as zero dollars. This was actually the itinerary item for the car rental expense incurred on 6/3 that is on your PB Travel 1 report, so I went ahead and let the system match them. Just wanted to let you know.
