Ruthairat
Can not submitted Expense of March 2025.
Hi @Ruthairat ,
Can you please close this pop-up window. Expand the error msg which is visible on of the report and provide screenshot here.
Need to check error message.
Ruthairat
Hi @Ruthairat ,
Attaching similar article for your reference purposes. You can refer to the below suggested solution.
@Ruthairat this article might help as well: https://community.concur.com/t5/Support-and-FAQs/How-Do-I-Clear-the-Alert-You-Have-Unsubmitted-Compa...
raluca_sandu
The error indicates that, according to company policy, it is necessary to submit certain Available Expenses generated from Bank Transactions. The system suggests that these may have already been included in another expense report. In this case, you need to proceed with one of the following options:
  • Submit the expense report where the entries were included first.
  • Or Move the entries to the "March 2025" expense report to submit it correctly.
Let me know if you need any further clarification!
