Akshata
CIP Certification
What is the procedure to become a CIP Certified professional?
Thanks and regards,
Akshata
2 Solutions
Karthikhemadri
@Akshata the CIP is provided to a partner companies employees. Your company should be a registered partner with SAP Concur so that the authorized person from your company can nominate you to  the CIP program. for details check - Certification - Step-by-Step Certification | SAP Concur Training
Karthikhemadri
@Akshata yes, partner means they are solely dedicated to implement or configure concur modules including expense travel request and invoice. In below link, you can search for partners with SAP Concur - Partners Search - SAP Concur
If your company is listed, check with your manager/HR to nominate you. If your company is not listed, you can still be nominated for advanced configuration training where you can make new configurations/changes for your company alone.
This has to be nominated by your company authorized person.
Karthikhemadri
Akshata
Thank you Karthikhemadri for your quick response. I have a confusion here. My company uses Concur expense module and travel module. Does that entitle me to get nominated? Or by registered partner, you mean a partner company dedicated solely to SAP Concur implementations, etc.
Awaiting your valuable response.
Thanks and regards,
Akshata
Karthikhemadri
Akshata
Thanks a lot. That clears my doubt.
Akshata
