- Mute
- Subscribe
- Bookmark
Audit Rule Question
I am trying to allow only 2 individuals within our organization to be able to allocate to 2 particular cost centers. I've been trying to add parenthesis but I'm not getting far...
- Mute
- Subscribe
- Bookmark
Hi @angelamcdonald, are you trying to achieve:
- ONLY those two employees can allocate to those two Cost Centers (i.e. block all other employees from using them); or
- Those two employees can ONLY allocate to those two Cost Centers (i.e. block them from allocating to any other Cost Centers)?
I'm assuming you want scenario 1 so you just need to change the comparator for Employee ID from OR to AND and it should work. Put single parentheses around the last two conditions (Cost Center).
- Mute
- Subscribe
- Bookmark
- Mute
- Subscribe
- Bookmark
That worked beautifully. Thanks so much!
- Mute
- Subscribe
- Bookmark
I was wondering what Event you use for this audit rule? I am trying to create the same rule for different policy groups (i.e. members of one policy group can only choose from a specific list of cost centers rather than all of them we have in our system).
- Mute
- Subscribe
- Bookmark
I was using Employee since the audit rule revolved around employee IDs.
