hshar41
Approval Flow in Concur
Do we have any approval flow in concur on the basis of the amount of the expense report.
For expense if a colleague is submitting expense for 100k so it should go to atleast Director or VP level for approval
MelanieT
@hshar41 Hello!  Yes, you can use an Authorized Approver workflow and base it on limit.  I have attached a tech publication for you with a lot of info on the Authorized Approver Info.
Another option is to have an Approver step with a change approver step that if a report is over $100k -> Change approver to Director.  Usually that looks like:
1st Default Approver
2nd Expense Approver - With change approver step to Director/VP
3rd Processor - Approved and In Accounting Review
Melanie Taufen
MelanieT
Melanie Taufen
