mkarraba
Administrative Reports
I am looking to run a report that shows all approved expenses in Concur. I would like to run monthly as well as annually. And I would only like to run reports for my direct repots. Does this report exist?
@mkarraba If you go into Reporting (found at the top of the SAP Concur home screen), you can see this data. I took a look and copied the Expense Entry Analysis report into your My Content folder. This allows you to choose a date range of approved amounts for either all or certain expense types and by employee. This report contains prompts for expense type, employee and Approved amount range. If you leave these blank, the report should include all expense types, all employees you can see (your direct reports) and any amount. You will need to choose the date range, though.
mkarraba
Thank you so much for the quick response! I was able to access the report. The only thing I am having issues with would be the employee section. It will only run the report for my own personal expenses. Is there a way to pull all of my direct reports information?
