Help! Ghost Card reconciliation in Concur
Hello!
We are looking into creating a ghost card for recurring charges within our IT and Facilities departments.  Does anyone have any experience they are willing to share with any problems/pitfalls with this scenario?  We are thinking of creating a PA id to tie the card for these charges in order for it to feed to Concur and then for recon and approval.
Thoughts?
Thanks.
MD
Re: Help! Ghost Card reconciliation in Concur
Hi MD,
The first thing to consider is how many charges are you looking at per month for the ghost card program.  The person that is assigned the card in Concur will have to reconcile and code each charge so as long as the number of charges per month is manageable, it should not be an issue.  At my prior company we had several ghost cards that were used for various types of purchases but only one was loaded into Concur.  The others had hundreds of charges per month and it was just easier to process through AP with an excel spreadsheet.
I too would like to know if anyone has experience importing ghost card transactions to Concur. Specifically around airfare. We have a ghost card for all our air transactions (which are several thousand a month). Because of this, the airfare does not going into concur and thus is not in the Cognos reporting tool.
Has anyone imported a ghost card for airfare? If so how did you do it. Assigning to one singular back office employee to reconcile the transactions would not be an option.
We are in the process of implementing Concur, and I was under the impression that if our TMC can pass the passenger name to the bank file, then Concur would be able to match that passenger name field to an employee's profile. Is this not true? It also would not be feasible for our back office to manually match every transaction.
The company I work for is in the same situation, where we use a ghost card to book all our flights but the ghost card is only mapped to 1 person and they are mannually attaching all the invoices, its a massive issue and we are looking for help resolving this issue
I do agree that an excel upload into the AP system would be faster and cleaner.  In our case, we want the employee to be able to change the cost center and add a project code if needed and have their manager approve the air transaction as well since we don't have pre-trip approvals.
Routine Member - Level 3
We're in the same boat here but I haven't found an answer in this forum or Concur yet. Add to that, they told me today they're adding hotel and car rental soon so it will be even more transactions. Sure, we can load them directly into our ERP, but then we lose the visiblity in Concur and we can't allocate to projects.
We do have our ghost cards on the global credit card feed and require one person to manage the expense report and reconcilliation in Concur Expense.  We have a monthly process and the statement amount must match the expense report.  all receipts are attached and reviewed for all charges.
the other option is to set up a virtual card program for each payment.
Hi there...which travel program are you under. We're with AMEX and have a feed that goes into Concur for report reconcilation. Is that what you're looking for  ?
