cjmarimo
How to move an expense from one report to another in the mobile app
In the mobile application I have not seen how to move an expense from one report to another directly, as can be done on the web.
How can I do it?
BR,
Josep
  Best Regards,
  CJ
2 Solutions
leedau
@cjmarimo There is no option to directly move an expense from one expense report to another.
If you need to move a quick expense (expense created via the + Create button on the homepage of the mobile app), ExpenseIt entry or card transaction from one expense report to another, you can follow the steps below:
  1. Open the expense report that contains the expense to be moved
  2. Scroll the expense from right to left
  3. Tap Delete
  4. Tap OK
  5. Go the Expenses tab
  6. Click on the expense
  7. Click Move To Report
  8. Select the desired expense report
This would be something you could submit as an improvement request. To submit a new improvement request or vote on an existing improvement request, please visit the Customer Influence Website.
Lee-Anne Dautovic
chriwri
Update to this answer - you now can move an expense from one report to another on mobile.
  1. Go into the report and tap on the expense you want to move.
  2. From inside the expense, tap the ... (3 dots) button on the top-right.
  3. From the menu, choose move
  4. A sheet will pop up, and from here you can either choose the report to move the expense to, or create a new report.
cjmarimo
Thanks Melanie.
I want to know how to move an expense from one report to another report.
  Best Regards,
  CJ
leedau
  3. Tap Delete
  4. Tap OK
Lee-Anne Dautovic
On 10/17/2023, we open the case 310357 - It cannot move an expense from one report to another directly in the mobile app on Customer Influence Website.
But no one has reviewed the request.
  Best Regards,
  CJ
chriwri
