DCormier
Unlock Feature for Passwords instead of a reset
JessicaL
Jessica
DavidW
Consider using Single Sign On (SSO).  This way, they don't need a separate password for Concur.
Maybe there are security issues with allowing an unlock. I'm guessing here, but seems like a plausible reason why there isnt' such a feature. 🙂
Dan54
The reset password link is never sent, never recieve.
Is a pain to connect/use Concour. "Nightmare" is the most appropriate term to define the customer experience.
And the Concour support is unreacheable. Each time when you need help, you got this message from their side "We apologize, an error has occurred while processing your request. Please try again later"
@Dan54 I wouldn't say the email is never sent as there are a reasons why a user wouldn't receive the email. One, the email address they use daily isn't the email address associated to their SAP Concur profile. Two, the user's email address was added to a suppression list for some reason. The user wouldn't know this. Three, on the SAP Concur sign in screen, user isn't entering the correct username.
If you send me a private message of the username you enter and the email address you believe is associated to your SAP Concur profile, I can check to make sure you have the correct information. To send me a private message, click my username (KevinD) then the message button.
kirstin_rintoul
I also can't believe that admin don't have this function!  We are about to go live and have encountered this issue with an account that has been set up to use for our video production.  We now have to delay - this should be a standard piece of functionality that Admin are able to override the lockout.
