akoshi
Travel Arrangers/Assistants - is there an Intelligence report?
Hello!  Is there a report that I can run in Intelligence that shows all travel arrangers/assistants for my university?
@akoshi there isn't a report in Intelligence, however we do have Travel Reports that can be run from within SAP Concur to show travelers and who their travel assistants are.
You will need to have access to the travel reports. If you have admin permissions at your company, go to Home>Report Admin. From this screen use the first drop down and select Users. Then use the second drop down to select your own name from the list. You will see a list of Travel reports appear on the left. Look for Travel - Travel Assistants, then add it. Click Save. Once saved, sign out and then sign back in. When signed in, go to Home>Reports>Travel Reports. You will see the reports available to run on the left. Select the Travel Assistants report link. Select the file output, then Submit. This will return the entire list.
akoshi
This is exactly what I needed!  Thank you so much!
