I'm trying to update my Concur Training Portal in our site with the new refreshed training materials since concurtraining.com will be retired.
I'm having trouble with updating the mobile section.
In Training Administration there is a Mobile tab but not a way to update the resources.
Has anyone found a way to do this?
Thank you!
@KellyAPIGroup I just went into your site and I don't see any resources listed under the Mobile tab. I'm not sure why that is. You might be able to use the SAP Help Portal to find links to mobile resources.
Use this link to access the Help Portal End User Guides list. https://help.sap.com/docs/CONCUR_EXPENSE/13094e09188143b09cef21883ba5873e/bb4e99add95a497ab6fe4451cc...
On the left-hand side you will see several options. Scroll down and you will see an option labeled Mobile App. Use the little arrow to expand and see all the different user guides. I believe you could simply right-click on each guide and copy the URL/link to use somewhere else.
